تلاش سپورٹ
مزید سیکھیں
how to NOT erase passwords?
  • 3 جواب دیں
  • 12 میں یہ مسئلہ ہے
  • 5 دیکھیں
  • آخری جواب بذریعہ Paul
Hi
The help article says Firefox Focus can "erase your browsing passwords".
Ok, how to NOT erase passwords?
Currently my passwords are NOT getting saved. How can you erase passwords if they're not being saved anyway?
Thx
  • @gmail.com.
Hi The help article says Firefox Focus can "erase your browsing passwords". Ok, how to NOT erase passwords? Currently my passwords are NOT getting saved. How can you erase passwords if they're not being saved anyway? Thx *@gmail.com.
Paul کی جانب سے میں ترمیمکی گئ
تمام جوابات (3)
Hi
I recommend either not using the trash can to clear the history, or using Firefox for Android, a full feature mobile browser that also has a private browsing mode included. You can find this in the Play store.
i'm not using the trash can. passwords still not getting saved.
Hi
Firefox focus is not erasing a password list, but would be clearing the history on any content that you entered into a page.
